    Dismiss Notice
Bathroom pull switch puzzle
Discussion in 'Electrics UK' started by Guitarmaan, 3 Aug 2014.
  1. Guitarmaan
    Guitarmaan
    3 Aug 2014
    8
    Thanks Received:
    London
    Country:
    Hi
    I attempted to swap over a bathroom pull switch because it was jamming. It's wiring looks like the first photo (not my own). But when I wired up the replacement switch it didn't work, and I don't understand why? I tried different wiring combinations and nothing worked. When I wired the old one back, it worked again (when not jamming). So the power and bulb etc all work. Is this new switch the wrong type or something?
    Original switch that jams
    New switch that doesn't work
  2. Sponsored Links
  3. RF Lighting
    RF Lighting
    31 Mar 2006
    19,990
    Thanks Received:
    1,354
    Leeds
    Country:
    Looks like you've bought a double pole switch. If you use the two silver coloured terminals only and leave the two brass ones empty you should be ok.
  4. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    As above, you have a double pole switch, so either connect live conductors across silver terminals or across brass ones, but not a combination of both.
  5. Guitarmaan
    Guitarmaan
    3 Aug 2014
    8
    Thanks Received:
    London
    Country:
    Despite the photo making it appear there is silver and brass, it's actually all brass. The terminal pairs are marked supply and load.
    So I started with the two marked supply (near the sticker) L and N. That didn't work so I tried using the load pair. Again nothing. Then I used live in supply and neutral in load. Nothing. N in supply and L in load, nothing.
    I suppose I have to conclude the new switch is faulty?
    I had a thought on the old one though, and I suspect the spring has lost it's shape. That would explain it sticking and not clicking back into position. So maybe I'll replace the spring and see how that goes.
  6. conny
    conny
    30 Jun 2008
    14,001
    Thanks Received:
    785
    Suffolk
    Country:
    When you connected one to the load side did you connect the other to the supply side in line with the load one or diagonally opposite?
    Both leads should be in line with each other. i.e. both to the right of the switch, (1 load + 1 supply),or both tothe left in the same manner.
  7. RF Lighting
    RF Lighting
    31 Mar 2006
    19,990
    Thanks Received:
    1,354
    Leeds
    Country:
    Connect to supply L and load L terminals.
  8. AndyPRK
    AndyPRK
    4 Jan 2009
    5,853
    Thanks Received:
    589
    Herefordshire
    Country:
    As said you both L terminals.
    The old switch is probably full of plaster so just needs cleaning out.
  9. Guitarmaan
    Guitarmaan
    3 Aug 2014
    8
    Thanks Received:
    London
    Country:
    Thank you guys!
    That must be the answer, because the only combination I didn't try was both L terminals load and supply.
  10. Sponsored Links
  11. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    • Thanks Thanks x 1
  12. Guitarmaan
    Guitarmaan
    3 Aug 2014
    8
    Thanks Received:
    London
    Country:
    Well, not really......
    I've never changed any electrical items before, and the part I bought didn't match the part already in place. So I had to make it up as I went.
    From a safety aspect maybe I was a stupid boy though. Messing with electricity when you don't know what you're doing isn't a great idea ;)
    Thanks again anyway, because I can confirm the light is now working perfectly :mrgreen:
  13. sparkwright
    sparkwright
    20 Aug 2009
    8,605
    Thanks Received:
    1,082
    Dorset
    Country:
    He's only joking.
    Great pic and slogan by the way.
    If you don't know, you don't know.
    What can fool people who don't know about electrical installations is that at a light switch like yours, the switch is connected to a permanent live wire and a switched live wire.
    There is no live and neutral at the switch - just perm live and sw live.
    In other words, at a switch, a black or blue wire doesn't mean it's a neutral, chances are it's a live.
    Usually a light switch breaks just the live and not the neutral.
  14. securespark
    securespark
    11 Jan 2004
    36,926
    Thanks Received:
    1,272
    Country:
    Quick!
    Hide from Ban.......
  15. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    No - you have to conclude that you don't know anywhere near enough about what you think it's OK for you to fiddle with.
    And that you don't have the right tools either.
    Please take the time to learn about electrics - trying to do it without a full and genuine understanding of how things work is extremely foolish. Your lack of even the most basic knowledge, such as what a switch does or what the conductors at a light switch are, could in other circumstances have been catastrophic. This time all that went wrong was you couldn't get a simple light switch to work. Next time you might not be so lucky.
  16. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    Not really... For what?
    For not knowing? No, of course not.
    For deciding that not knowing should not in any way be a reason not to do? A strong case.
    Do you really think that's a sensible basis on which to attempt electrical work?
    It's far worse than that. It can kill. Really, it can.
  17. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    Indeed.
    But if you don't know then you don't fiddle with it - it really is that simple.
Loading...
Share This Page
