Bathroom Radiator Not Working, Air Block?
16 Jun 2014
Water is definitely coming into the radiator ok, we drained
the radiator and then turned it on, it warmed up but then
the radiator got cold.
So this means the water is not leaving the radiator?
Any idea how to sort this out would be great.
Thank you for the replies.
The Bathroom radiator is not connected to the other rads, it is
on the hot water system connected to the other plumbing -
taps, shower.
The radiator has a tap on one side so you can reduce the heat.
The cylinder must be robbing it has it got gate valve on the circs close it if rad works open gate valve enough til u feel pipes hot
Have u checked if circa at cylinder are hot if so is valve fitted?
Sorry for the late info and thanks for all the replies,
will run some checks.
