- Joined
- 5 Dec 2012
- Messages
- 1,019
- Reaction score
- 15
- Country
My mind is a boggle with everything I've got on the go at once.
Currently my floor is up and joists exposed as I am levelling it. I am installing a new bathroom comprising of a 1200. X 700 shower tray/enclosure, a wall hung semi pedestal (going on stud wall) and a new toilet remaining in same place as it is now.
Can I just confirm the order of everything?
As my floor is exposed joists, I plan on first fix water supply and bringing the pipework up through the floor alongside stud wall as I will be boxing in the water pipes and shower waste pipe.
I assume I install noggins for semi pedestal before boarding up?
I want to bring my basin waste down into my shower waste. Should my basin waste be 32mm pipe? And shower waste 40mm? Is there a t connector you can get to connect my vertical 32mm pipe into a horizontal 40mm pipe run?
On a semi pedastal i believe the waste pipe will run down through stud wall - then do I bring the waste out of the wall and connect into horizontal shower run at floor level so it will be boxed in?
