I'm installing a bathroom light which incorporates a shaver socket - its double insulated, class 2.
I'd like to feed it from a ring which just happens to be under the floor in the right area.
Can I do this using a FCU? The FCU can be fitted in or under a bathroom cupboard. Does the FCU need to be an RCD type?
Incidentally there is no earth connection - I'm assuming the fitting doesn't need to be bonded - am I right to assume this? (not that I could anyway with no earth connection).
Thanks in anticipation
