    Dismiss Notice
Bathroom Wall Panels - Wetwall, showerwall, multipanel :-S
Discussion in 'Plumbing and Central Heating' started by fred1981, 8 Jan 2015.
  1. fred1981
    fred1981
    8 Jan 2015
    7
    Thanks Received:
    Caernarvonshire
    Country:
    Im looking to renovate my bathroom by installing a quadrant shower enclosure in an unused corner of my room.... dont know why one was never installed to be honest. Plumber friend says the same and its an easy job...
    confusion i have is that i dont want it tiled and would like some wall boards but there so many im not sure which to go for.
    I dont like the plastic panels as ive had them before and just dented to easy so looked into harder boards and was told about mdf backed boards called showerwall. see some in my local builders merchant and its solid so good stuff for me. Googled them and found a website which sells them at a a much cheaper price then the builder merchant and will deliver for free as well which is great. confusion came when i started looking through their site and found there other boards which appear to be the same or similar and all priced different..... showerwall, wetwall, multipanel, selki, does it really matter which i go for??
    website is http://www.rubberduckbathrooms.co.uk/shower-panels-boards
  2. Sponsored Links
  3. Nige F
    Nige F
    28 Jun 2005
    21,204
    Thanks Received:
    1,741
    Country:
    Multipanel by Grant Westfield :idea: ...got it here @ home . BUT make sure the floor/walls are true first. ;)
  4. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    You've probably chosen by now - I'd be interested to know what you went for and why.
    I have a serious worry about the MDF based ones - I fear that no matter how well you put together the joints with sealant and metal strips, water will penetrate. It might take years, but sooner or later the MDF core will do what MDF does when you make it wet.
  5. Burnerman
    Burnerman
    7 Feb 2008
    23,143
    Thanks Received:
    4,500
    Northumberland
    Country:
    +1 for the MultiPANEL.....using the genuine trim and joining strips. Its ply based, costs a bomb but is absolutely great.
    John :)
    • Like Like x 1
  6. Sponsored Links
  7. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    And what does ply do when it gets wet, repeatedly/constantly?
  8. Burnerman
    Burnerman
    7 Feb 2008
    23,143
    Thanks Received:
    4,500
    Northumberland
    Country:
    It delaminates or deteriorates......like most organic materials.
    John
  9. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    Which is what worries me, even if the core is "WBP exterior" ply (A term which covers a multitude of qualities)...
  10. Burnerman
    Burnerman
    7 Feb 2008
    23,143
    Thanks Received:
    4,500
    Northumberland
    Country:
    I couldn't agree more and success has, as with many things, got to be down to the ability and professionalism of the installer to know what is required.
    If installed as per manufacturers instructions all should be well, but cut corners and it'll come back to haunt.
    When I used this stuff, maybe 10 years ago, I sealed the raw edges first before using a quality silicone and it's fine to date.
    Curiously enough I'm having another bash in a month or so!
    John :)
  11. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    I'm thinking I might try and find (a) maker(s) who offer the same finish in solid laminate (which I'd happily use on wet walls) and plywood core boards which would be OK on walls which don't get soaked.
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
