Now that's interesting so the batten holder would screw into the box? Would it, therefore, be easier to use the loop-in type to connect holders together?A batten holder fits neater on a conduit box, but screw heads are visible, any extra wires can be terminated inside the conduit box using connecters, a loop in one hangs over the sides as its bigger
View attachment 171811![]()
Loop in batten...............Plain batten
It is technically also a loop in.View attachment 171819 This one is listed as loop-in at screwfix?
Could I not connect the lights together (daisy chain) before the the junction box? I have a 6 metre conduit 1 light at each end with 1 in the middle. The supply and 1 switch enters from the right and the other switch enters from the left currently meeting at a 4 way conduit box. Its evident I will have to introduce a 17th edition box or similar?Yes, then it would be possible to do what you say. It would be lots of wires in the junction box - I make it 18 wires into 5 connectors.
Would it not be possible to run the supply to one of the switches, then to the other switch and one of the lights and - and then from that light to the other two?
