Baxi combi 80e no flame
If the pressure isn’t going from about 1.5 bar when cold into the red when the heating is on, you can rule out the expansion vessel.
The PRV needs cleaning or changing
the pressure is not rising into the red, but the radiators are not getting hot now. The heat flow pipe coming from the boiler is hot though as is the pump. The radiators have been bleed and valve on radiators also are open
The hotwater function works perfectly fine
Sort your PRV issue and see how it works then.
Thanks, I tried the inplace cleaning but still losing pressure slowly. I have ordered a new PRV, will see if that makes any difference thanks.
I put a new PRV on. But there still seems slight leak of pressure dropped about 0.2 bar over 3 to 4 days. No visible leaks on the boiler. Not done the balloon trick on the external relief pipe yet. Is there anything else I need to check?
The heating and hot water seems to be working fine.
