Baxi solo he won't fire up
12 Aug 2013
Berkshire
I have a baxi solo he that clicks on both green lights come on then within 3-4 seconds cuts out with the light next to the power light going red. It then tries to start several times doing the same thing then it stops.
I have tried switching the thermostat to full but this makes no difference.
If anyone has any thoughts on the problem I would be grateful.
26 Jun 2004
London
It may well be a gas/combustion issue which is not suitable for a DIY repair.
Could also be the PCB at fault too.
You will probably have to call a gas reg engineer.
Tony
