A similar question was asked on this forum about bedding a WC onto a solid floor. I would like to know if my situation is the same. I have a back to the wall WC which is going on top of water resistant chipboard floor covered with Karndean (similar to Amtico). There is a small movement because the pan botton is not perfectly flat due to firing. There is only a 10mm rim in contact with the floor as the rest is a void. I was thinking of using Plumbers Mait to bed round the rim and then finish off externally with a bead of silicone. Would this be OK?
