Bedroom light wiring info
Leave the red wire that was loose where it is (L4)
Put both of the other red wires in the same terminal, (L1).
Either that will work, or it will work but the switch will seem upside down.
Ok
So now as follows.
Red still in L4.
Red from L3 now with red in L1
Bedroom 2 & 3 work fine.
But
Bedroom 1 light always on and when I operate switch it turns off bedroom 2 & 3
But
Those statements are contradictory. Are bedroom 2 & 3 lights working fine, or are they working only when the switch in bedroom 1 is off?
Bedroom 2 & 3 lights turn on and off when using there respective bedroom switches.
Bedroom 1 light is on all the time regardless of its switch position.
Now because it's always on I don't know if the switch is on or off but when I operate the switch it then switches off bedroom 2 & 3.
Operate the switch again and bedroom 2 & 3 come back on.
Move one of the two wires from L1 to L4.
50/50 you get the right one.
So
One red in L1 then take the other from L1 and put with the existing wire in L4 correct.
