Hi All
Hopefully an easy one for you. I need to lift a bedroom floor slightly so that it is approx level with the bathroom tiles when carpeted. I've got a few sheets of 5mm ply which i'm going to lay over the existing 22mm chipboard T+G floor. Should bring it up enough. Not sure if the t+g was the moisture resistant type. I was planning to use 12mm staples in a staple gun and/or 20mm screws every 200mm.
I would also like to glue the ply down. Any ideas what type of glue to go for ? I was thinking normal PVA but maybe this is too weak. Does the fact that the boards maybe moisture resistant affect the bonding ability of the glue ?
Once the ply is down it's gripper rods / underlay and carpet.
Many Thanks
Wert
Many Thanks
Wert
