Best choice for weatherproofing new timber garage wall thats not seen
27 Sep 2021
Hey guys, im about to build a timber framed garage in one corner of my drive, i plan to clad it with feather edge as i have a stash already, however one long wall will be very close to a fence and totally unseen, it seems a waste to use my precious featheredge so was thinking of cheaper alternatives here as aesthetics aren't really an issue?
can i just use roofing felt? any tips of how to hang it vertically? the build will be 3x2 studs at 400mm centres with 12mm ply sheathing then a breather membrane.
12 Jan 2014
Essex
My dad in the past used dpc then put 3 ply felt Don the sides behind the French you couldn't see, seemed to work well.
He nailed it on. And then black jacked over the nails, overlapped the joints and black jacked them also.
15 Sep 2017
S. Uplands
12mm cement board - STS construction board for example.
or box profile.
Are you using vertical battens to create a cavity -important behind timber cladding
