As per title, new build(ish) double garage floor has a few layers of paint build up over the several years it has been down.
Overall it is in good condition, with a few small (but long) surface cracks - nothing I am too worried about. I am also not after 'perfection' only that the 2 part epoxy paint (thick layer) onto the primed surface does not lift.
Local hire place has a couple of choices of machine for me. I have ruled out scrabber machines as the surface is already pretty smooth & even.
1) Upright diamond floor grinder (CON17) 1 DAY = £75.60 2 days or W/E = £94.50
transformer to suit (TRA78) 1 day =£12.00 2 days or W/E £15.00. + £30.00 per 1/2mm wear charge
2) Twin head floor grinder (CON05) (not diamond) uses 6 x carbon block, 1 day = £63.00 2days = £78.75 transformer to suit (TRA76) 1 day = £24.00 2 or W/E £30.00. grinding blocks are £4.00 ea
WITH...
3) Dust extraction unit (CUT75) 1 day = £68.40 2 days or W/E = £85.50
Now, he warned that some of these machines don't work at domestic properties due to the electrical load. He wasn't willing to explain how/what/where I could confirm this. The garage is several M from the house - up to 10m from end point of garage, though the garage itself does have it's own supply to MCB. I also had my electric upgrade the 32A breaker from 'B' to 'C' as my 2.1kw pressure washer tripped it on start up.
Any thoughts/advise on the machines?
Many thanks
WITH...
Many thanks
