Hi, I’m looking for some advice on the simplest and correct way to block up this existing opening for a new window.
The new window is 450mm wide x 2020mm high. In one of the photos I’ve stood the new window in front of the existing opening to show roughly where it will be positioned.
What I’d ideally like to do is use as much of the existing blockwork/brickwork as possible and build directly from what is already there, rather than cutting lots more of the existing masonry out and rebuilding the whole opening.
Looking at the photos, what would be the best way to block up around the new window using the existing masonry as the starting point?
There is considerably more space to fill on the left-hand side, while the right-hand side is quite narrow. I’m particularly interested in how you would lay/cut the blocks in these two areas and how you would tie the new work into the existing masonry.
I basically want to know how a builder would make best use of what is already there and block around the new window with the minimum necessary alterations, while still doing it properly.
The existing concrete lintel is staying in place.
Photos attached showing the existing opening and the new window.
Any suggestions on the best block layout / method would be appreciated. Thanks.
