Best way to fill a gap between plasterboard and wood architrave
19 Aug 2016
I have a gap of 10-18mm on the hallway ceiling, as it meets the architrave of the landing/staircase:
I was wondering how to fill it, to avoid cracking? Someone said I need plasterboard beading, but I'm not sure how I would use that? Someone else said to use scrim tape and 2 layers of filler? Any suggestions appreciated
I've actually used expanding foam in situations exactly like that and will probably go to hell for it.
Why not cut it back and use a larger (wider) piece of plasterboard?
I'm just decorating, I can't mess about with the plasterboard . Really looking for a way to fill the hole...
Would you then cut it back and caulk it?
Anything paintable that cures (caulk) is likely to shrink back in a gap that size. Can you not cover it with a flat trim?
Most builders merchants/sheds have a mouldings or beadings section. As do plastic stockists which stock a plastic equivalent. I'd be thinking some kind of timber single bull nose 8mm thick by 40mm wide trim or summat.
Thanks for the link Noseall. The trouble is the plasterboard is flush with the architrave at some places, and a few mil higher in others.
Ok, I think I need to do as you say and use some flat trim over both the architrave and the plasterboard
