Best way to fill hole In plaster under window sill
11 Nov 2018
Hi all
Removed wallpaper in my bedroom and it's pulled lumps of plaster off in certain areas, pics attached
What's the best product/method to repair
Thanks in advance
Sprocker, good evening.
I would consider using expanding foam below the sill, this will possibly eliminate ant draughts, allow to set and cut flush with the plaster.
Also worth thinking about ? is to fix a vertical facing timber directly below, and in contact with the sills front protruding edge?
Ken
