Best way to seal and insulate around garage door frame
30 Jan 2011
Middlesex
I want to seal and insulate the tiny gaps around my garage door frame from the inside. I have a standard single-width up-and-over metal garage door. I noticed that the frame has been bolted into the brickwork and the tiny gaps haven't been sealed.
What's the best way to ensure a good airtight seal between the garage door frame and brickwork, preferably with good insulation properties.
I was considering using expanded foam.
2 Feb 2006
Staffordshire
Ex-foam is excellent as a gap filler that does not conduct heat, however it is lousy at weathering externally.
Fill any gaps, cut off the excess then fit a bead over the foam or recess the foam back and caulk it with silicone.
