Mrs BB's parents have a BG homecare arrangement which provides them with annual safety check/minor servicing.
BG guy has left a note saying "NCS - internal flue around wall not sealed".
Turns out the boiler wasn't installed correctly, guess who did the install - yup! BG!!
The hole in the kitchen wall is a bit of a sore point. They have been arguing with BG to come and re-instate this from when the install was carried out - the hole is much bigger than you would expect for fitting a flue (took out approximately 500mm square hole and only part patched it up with a bit of loose brick and a lot of foam filler).
Just another example of how you can't always trust those who you should be able to...
