biasi boiler problem
He means that he wants the pump head.
In fact most Biasi models do have only the pump head listed although not many merchants want to list them. They are still quite expensive.
Its more complicated because there are three different types of pump used on that model of boiler.
Its also relevant what wrong with the pump. Probably the pump bearings worn out. If it were the motor then it would probably be possible to fit your can into a new generic Wilo pump winding. But all those possibilities require an engineer who is keen to be helpful to keep the cost down and not many are and they just offer the manufacturer's standard part.
If you call Biasi technical help and ask them for the part number of the pump head only after giving them the serial number they may be able to tell you one.
Tony
