Hi, hope someone can help. Model is M110.32SM/C, a few years old. Came home this evening to a cold house and a lifeless boiler but found that the mains plug had been dislodged and wasn't making contact properly. When it was plugged in properly the boiler came back to life for hot water which was a relief but it won't respond at all for CH. Thermostat is calling for heat,(I bridged the connector at boiler to make sure). The system pressure is reading 1.5 bar and the fuses on the pcb are intact. The left hand operation light pulses every four seconds with function selector switch to O, and every two seconds with function selector turned up. Non of the other operation lights illuminate unless hot water is drawn.
