Bit of advice with creating stud walls in kitchen
10 Sep 2022
Okay so I am not very good with explaining so I will keep ot as simple as I can
Straight to it I am looking at creating a
stud wall that are built flat onto the existing walls
The idea is to use a stud wall to step out part of the kitchen where I am building custom kitchen unit
I will be covering the stud in mdf rather then plaster board and then attaching the units to the stud wall
The idea is to use the new wall to step out and straighten the kitchen but also aid a rewire
I want to use mdf rather the plaster board for ascetic reasons
Sorry for my bad explanations and typing I am not very good
Is it safe to add a stud wall onto and existing wall
Can I cover in mdf
Ahoukd I insulate it or leave it empty
I am very technical minded and am qualified electrician and plumber
I am more of a worrier and want to dk things right at the same time as get the results I want
Yes, it's safe to do. The practicalities of using MDF in a room which will have excess humidity should be considered.
If the external walls are solid, then consider throwing some quilt insulation between the studs
Thanks woody
I am making all units using mdf so the thinking was using the same material for praticalltoy of ordering really
What would u recommend as good coverings for a stood wall in the kitchen
The units will be primed protected and painted as all kitchen units
Any recommendations for the stood wall would be amazing
Would a hard or soft plywood be better for the stud wall ?
Only part of this ply will show the rest will be behind units
And what does show will be cover in a plashback
