Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
4x2 normally. Ask for cls when you order the timber. What's gonna be on either side of the wall? There's a neat trick you can do with 3x2 on a 4x2 baseplate, if soundproofing is a requirement, see here:
I always screw stud walls together. If you need to adjust it whilst constructing it you can simply undo them. Plus they never ride out. Use 12.5mm plasterboard and screw them to the studs. Again, screws dont ride out so the heads wont popthe plaster.
There are no directions in building regs on what materials may or may not be used for ordinary stud partition. 15mm plasterboard is sometimes specified when the wall is a sound wall that needs to comply with Part E (Sound) but even in that situation there is nothing stopping you using timber stud as long as the finished wall passes the post test.
If the wall is a sound wall you may need to rethink. Otherwise use cls timber stud with 12.5 plasterboard. Personally I would nail the frame but always screw the plasterboard. What size cls you use depends on how solid a wall you want. 75x50 is very common but if you want something a bit more solid you might use 100x50. And for even more solid put 100mm mineral wool between the studs and face with 15mm plasterboard.
The 3x2 staggered stud approach (see my post above) would've been better, and slightly cheaper. You can use 12.5mm and get better performance than 15mm on a single 4x2 stud. Insulation between is important as well though.
