    Dismiss Notice
Bleed nut on radiator will not open
Discussion in 'Plumbing and Central Heating' started by PHIL269, 5 Nov 2021.
  1. PHIL269
    PHIL269
    26 Sep 2012
    96
    Thanks Received:
    London
    Country:
    Hi
    I am trying to bleed a radiator but the nut will not open.
    Are there better bleed spanners maybe ?
    It is the type that is at the black of the radiator and faces the wall.
    Also should the heating be switched off when I try to bleed it please ?
    Thanks.
  2. Sponsored Links
  3. CBW
    CBW
    26 Sep 2019
    9,633
    Thanks Received:
    2,633
    North
    Country:
    That’s going to be awkward, and they’re not the best for access. Do you mean bleed key, or are you actually using a spanner?
  4. Madrab
    Madrab
    4 Oct 2012
    8,544
    Thanks Received:
    2,474
    East Renfrewshire
    Country:
    Only a radiator key would normally be the correct size. Are there any better .... depends on what type you are using and whether it is a good fit or not. Any more effort than what a normal clock key type can apply usually ends up with the bleed screw snapping.
    Doesn't really matter whether the rads are on or not to the actual bleeding process but always better to bleed when cold to avoid any scalding risk from hot water.
    • Like Like x 1
  5. ianmcd
    ianmcd
    15 Aug 2010
    23,955
    Thanks Received:
    10,055
    Livingston
    Country:
    Best to have the heating switched off when bleeding, some, not all sytems can actually draw air in rather than out if the pump is running when you open the bleed point
    • Thanks Thanks x 1
  6. PHIL269
    PHIL269
    26 Sep 2012
    96
    Thanks Received:
    London
    Country:
    will putting wd40 on the bleed valve help ?
  7. PHIL269
    PHIL269
    26 Sep 2012
    96
    Thanks Received:
    London
    Country:
    when you say have heating switched off is that boiler can still be on but heating not on and radiators cold
  8. oldbuffer
    oldbuffer
    6 May 2010
    1,489
    Thanks Received:
    559
    London
    Country:
    Have a look at BES 7499
  9. ianmcd
    ianmcd
    15 Aug 2010
    23,955
    Thanks Received:
    10,055
    Livingston
    Country:
    just turn it off at the controls so the pump isnt running
    • Thanks Thanks x 1
  10. Sponsored Links
  11. ianmcd
    ianmcd
    15 Aug 2010
    23,955
    Thanks Received:
    10,055
    Livingston
    Country:
    nope, get a proper tight fitting rad key made of Brass, and a small adjustable spanner and it will come out, the grey keys are absolutely useless
    • Thanks Thanks x 1
    • Like Like x 1
  12. polesapart
    polesapart
    27 May 2011
    1,384
    Thanks Received:
    362
    Country:
  13. Wayners
    Wayners
    24 Oct 2020
    395
    Thanks Received:
    98
    Country:
    Ones that I can't budge and round off having tried to remove to let air out I get a small socket and hammer on. Couple of taps to get it on.
    The really old brass type are so soft socket goes on easy moulding the plug to the socket shape.
    • Like Like x 1
  14. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    9,455
    Thanks Received:
    1,279
    Country:
    Generally, no. A bit of heat from a pencil flame blowlamp might help, if you have access.
  15. fixitflav
    fixitflav
    20 Mar 2018
    1,323
    Thanks Received:
    151
    Stoke-on-Trent
    Country:
    If he gets that type I suggest filing it down flat to get rid of the internal chamfer. I have a small socket set for use on car alternators, which were like that. With the bolt heads being quite shallow filing flat gives much better engagement and less risk of rounding off.
    • Like Like x 2
  16. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    9,455
    Thanks Received:
    1,279
    Country:
    Best only used for undoing them - that type give far to much leverage for closing them, they don't need to be that tight.
Loading...
Share This Page
