Blown toaster -> plug socket no longer working
Discussion in 'Electrics UK' started by xplosiv, 11 Feb 2013.
  1. xplosiv
    xplosiv
    9 Sep 2007
    93
    Thanks Received:
    Bristol
    Country:
    Hi all
    I was making some toast and the toaster went pop. Now the double plug socket in the kitchen isn't working. All the other sockets are fine and the fuse box looks ok. Any idea what the problem is and how to fix it? Is there a fuse in the actual socket that needs replacing? Any help appreciated.
    Thanks!
  2. Sponsored Links
  3. pjcomp
    pjcomp
    22 Jun 2010
    556
    Thanks Received:
    76
    Country:
    There isn't (usually) a fuse in a double socket, but there should be one in the plug attached to the toaster - have you checked that one? IS it both sides of the double socket don't work or just one? You say the fuse box "looks" OK - are they fuses or switches? If switches they're all presumably in the same position; fuses can only be checked with a meter, not by visual check alone.
    PJ
  4. xplosiv
    xplosiv
    9 Sep 2007
    93
    Thanks Received:
    Bristol
    Country:
    I 've tried a different appliance in both sockets and neither work. The fuse box has switches. All the switches are up with the exception of one switch which is half way - but that one is labelled 'electric shower'. We don't have an electric shower and I'm not even sure there's a fuse in there, and i think it has probably always been in that position.
    It's strange the fuse box has all the switches up still. Is it possible the toaster blowing has damaged the wall socket somehow and needs replacing?
  5. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,632
    Thanks Received:
    2,141
    Oxfordshire
    Country:
    That half way switch is probably an RCD (does it have a test button on it?)
    Push that switch all the way down and then push it up to the on position.
    Then try your rogue socket again.
  6. xplosiv
    xplosiv
    9 Sep 2007
    93
    Thanks Received:
    Bristol
    Country:
    That did the trick - much appreciated! It's possible the 'electric shower' switch was labelled incorrectly I guess. Glad it's sorted, thanks again!
  7. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    So you've got one kitchen socket on a circuit of its own?
  8. Sponsored Links
  9. xplosiv
    xplosiv
    9 Sep 2007
    93
    Thanks Received:
    Bristol
    Country:
    No idea. I've never had any electrical issues since I moved into this house over 5 years ago; today's toaster incident has been the first time something like this has happened. Im not going to analyse it too much - ust it's working again!
  10. RF Lighting
    RF Lighting
    31 Mar 2006
    19,990
    Thanks Received:
    1,354
    Leeds
    Country:
    I bet it was the old cooker radial which someone has put a socket on to the end of.
    When the CU was swapped the 'electrician' couldn't find what that 6mil cable did, so just guessed and labelled it shower.
  11. Robin0577
    Robin0577
    16 Aug 2011
    588
    Thanks Received:
    111
    London
    Country:
    RF, are you suggesting that an 'electrician' would reconnect a random cable without knowing what it did? How would (s)he measure loop impedance without finding the other end of the circuit? tut tut... :p :LOL:
    I wouldn't do that and I'm not even a "proper" electrician...
  12. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    You'd be amazed at the things done by some people who claim that they are.
  13. Robin0577
    Robin0577
    16 Aug 2011
    588
    Thanks Received:
    111
    London
    Country:
    BAS, I have seen and have been amazed by many such things!
  14. Scoby_Beasley
    Scoby_Beasley
    1 May 2003
    1,881
    Thanks Received:
    50
    Durham
    Country:
    Or something behind the socket went boom and now running two radials instead of a ring
  15. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
