Added for prominence: Bodger tip! A DIY nutter comes up with something that works quite well (and something toxic that works very well)! After scraping off the easy stuff with a wallpaper scraper or one of the many mechanical scrapers around, the real stuck down bad stuff which comes up in tiny clumps and threads can be cleaned up easily with Brillo pads soaked in white spirit. The really nasty idea is at the end because you really want all the safety gear if you're going to play with it. I only used a bit and I'm high as a f****** kite.
I want to lay over these tiles with something pretty like slate, but I'm having a real hard job cleaning them up. Can those with the know help?
I lifted the three layers of vynal tiles with a heat gun. This left a horrible glue residue everything sticks to making my floor dirty and horrible. This sucks as I still have to live in this place while doing the work.
Here are the things I tried:
HG Floor Glue Remover: Absolute joke. Barely weakened the glue at all. Layed it down for the 15 recommended minutes and scraped, hardly any glue came up. So I gave it another chance and left it for a day, same result.
Low-Odour White Spirit: This is the best thing I tried so far. It's far from perfect but gets a good 80% of the gunk off with scraping.
Angle grinder with wire brush attachment: Using this in combination with Low-Odour white spirit makes for tiles that look clean apart from the pitted parts.The trouble is, once the spirit evaporates they immedately begin to collect gunk again like there is still glue on them, except you can't see what it's sticking to.
Cilit-Bang: Not bad actually since it's just a cleaner. About as effectivr as HG floor glue remover.
I have ordered a jesus saw (Bosh Multimaster knockoff) attachment the rigid and flexible scrapers. Can't wait to try them out when they arrive but I'm not expecting miracles.
Should I put on a respirator and dump a bunch of muriac acid on them? I'm at my wits end, this small room has eaten about 20 hours of my time so far.
