Recently I've been re-appraising my energy costs and monitoring electricity usage with those power meters that attach to the cable coming into the home to the master switching box. I went around turning everything off but could never get to 0. There was always a constant 50 watts usage. I found out that it's the boiler (Saunier Duval Thelia 623). If I turn it off at the master switch on the wall then I get 0 electricity usage. I just had a word with my landloard and he says that's normal and is needed for the pump to work every 24 hours to prevent cold seizing the pipes and for the extractor fan to keep the pilot light lit. I can't turn it off at the wall everyday because the pilot light will go out and I would have to kickstart it again. Plus it might be problematic (like the system seizing up in the cold). I'm kinda miffed that it's drawing power (albeit not a great deal) when it's doing absolutely nothing as far as I can tell.
Is this really normal and is it just that my boiler is old and not energy efficient?
