Hello Helpers,
When I came in tonight the pressure on the boiler seemed unusually low but still within its allowance. I turned the thermostat in the hall up to 30. Thereafter, I realised that the boiler seemed to have been on for a while and when I looked at the needle it as just into the (high) red. I turned the thermostat in the hall back down and the boiler switched off and the pressure gradually dropped as normal. I put the thermostat back onto to about 27 and again I had to turn it down as I feared the boiler's needle was heading for the high red again. Then I had a couple of shots with the thermostat at about 22 and the boiler switched on and then off again as normal.
I'm guessing that the original low pressure may have been a result of the pressure being too high previously without me knowing and discharging some water outside.
I do have a contract with British Gas but I don't want to dive to contact them without taking good advice from your goodselves. Any observations would be most welcome and particularly as to whether I have a problem with the boiler or with the thermostat in the hall.
Thank you in anticipation of your very kind assistance.
