Hi
Our Hot Water has been coming on at around 3-4am in the morning despite the timer being switched off. The Central heating is off.
I know there are 2 x Zone Acuator Valves (Drayton ZA5 2 Port), one for Hot Water and One for Central heating. Digging around in the dark, I can see that the valves are both in the 'A' position, so closed. I presume the Thermostat only calls Central heating so am ignoring that. THe only way of stopping it is to power down the boiler.
In the morning I experimented with the Hot Water Value - call for water switches it on (you can see the motor move from A to B and hold it. If I switch it off, it returns to A. I've sent the videos of how its working internally, and it looks to be working - switching on/off.
SO ....
If the Timer is OFF. If i've discounted the Thermostat because its hot water not central heating. If the Valve in question 'appears' to be working.
What on earth is it?
It had been working fine for a long time. The boiler is relatively new, serviced, all installed by professionals. So dont think a sudden-wiring problem could occur.
Ideas? Or things to try?
SO ....
