- Joined
- 6 Feb 2021
- Messages
- 2
- Reaction score
- 0
- Country
Hi
Just seeing if there's anything I can do about a problem with my boiler (Baxi Solo PF2).
Over the last few days as the house gets warmer, the boiler doesn't cut out as it should. It's usually after an hour or so of the heating being on & initially the boiler will cut in & cut out as it normally would for the 1st hour, but then will often stay on & not cut out until the water in the CH pipes & radiators gets so hot it boils over into the overflow tank. (F&E tank?)
At this point the room thermostat temperature hasn't been reached. It's a vented, pumped system, I think these are the right terms.
Any ideas what is causing this? Any other information needed?
