- Joined
- 26 Aug 2016
- Messages
- 6,830
- Reaction score
- 1,009
- Country
If those two are hot the cylinder is heating up. Check another hot tap perhaps.Just checked the the pipes. These two are hot but still no hot water. See pictures for more info
Some amount of warmth will be conduction. Without a suitable thermometer we don't know how hot. All the pipe work should have been insulated, so it shows the installer didn't do everything.If the t@p relief valve is hit, I’d say there’s an issue, unless it’s transference?
it will heat water at the rate of about 1 litre per minute.
I've added a picture on
Push him off, it would be very unusual for the Horstmann programmer to be tripping the RCD but is possible which Horstmann do you have ? post a picBTW does anyone know how to remove the horseman
That will be a zone valve actuator and if water has been getting in there that is your problema silver rectangle box at the mid left of the boiler
