The story started many weeks ago, but the boiler seemed to be working fine so I was taking my time investigating replacements etc. I think its come to head today at the worst possible time, my wife and 2.5 yr old some return from holidays on Sunday and seems the system is well n truly goosed.
Went out in the evening, only to coem back to find a bit of water dripping from the bottom of the cylinder. I switched it off, took the front panel off, then then the steel plate behind it, as which quite, quite a bit of water rushed out.
I don't know much about boilers, but it looks like the internals or the HExchanger have developed a leak. I checked the piping going in and out of the boiler and that seems fine until it disappears inside the boiler.
Edit: I also closed the main gas valve on the meter and lit a stove to remove any gas inside the house.
Queries:
a) Is it safe to disconnect power to the boiler or is there anything else I should do.
b) Would it be OK to use the electrical immersion heater to get h/water?
c) Would doing (b) potentially cause more leakage from the boiler?. Is there any wat to isolate the water going in and out of the boiler?. I suppose I could close the isolating valves on the pump to close of the discharge side, is there a similar valving arrangement on the inlet?.
Thanks for any help. I gotta call the heating company I've been talking to to see whats the earliest I can get this sorted, have a feeling I've severely undermined my position to haggle a reduction in price
Riz
Queries:
Riz
