Boiler presure dropping off
17 Mar 2006
Ayrshire
Hi, I've just had a new rad fitted in my bathroom, part of refurb of bathroom. Now the pressure is dropping off constantly in the boiler, the pressure gauge reads zero, when system is turned off. In order to get the system to heat up again I have to refill the system to 1 bar. Is there any tests I can do to isolate or identify the cause of the pressure drop, all the pipes for my new rad are concealed either in the wall or beneath the floor.
I hope they were tested before covering. If the presssure relief valve discharge is not dripping then you may well have to get your installer back to find the problem. I'm assuming everything was OK before the new rad install.
Yes the CH system was working fine. I maybe topped it up about a year ago>. Since getting rad done, I have topped it up everyday. When the timer turns off the system pressure drops off, so that when it is due to come on again there is no pressure. So I have to refill the system to get the rads to heat up?
