Boiler problem
28 May 2009
Durham
Over the past few weeks, the boiler has not heated the water all the time. I've put more pressure into the boiler using the valve but this does not seem to work. The pilot light is on. When I run the tap slowly, sometimes the water is hot.
I'm stuck, please help.
The boiler is a Worchester Bosch 240
Graham
Sounds as if the plate heat exchanger is blocked.
But if you have described the symptom badly the diverter valve may have failed.
Tony
PS Worchester is an area on the outskirts of Joberg!
Sorry the principle is correct but its not a plate its a losenge shaped thing.
I do have to say they dont block so often though on that model.
The OP's description of the problem is a bit thin and different conclusions might arise if a few more words and info was given.
Tony
The boiler used to heat the water through the day but running a bath on the night was cold. Now the water runs cold most of the time. This has just started happening after the boiler was serviced (about 6 weeks ago). Is there anything I can do? or should I just call a plumber?
Thanks for you responses.
Graham.
Grabster, how much time did your plumber take to service the boiler.
If he does not know how the boiler works, it is time to look elsewhere. To be fair to him, the diverter could have developed a fault during the six weeks. You may want to get him back and suggest he looks at boiler operation during HW demand.
15 minute spring clean is no service.
Tony do you really mean it?
Graham.
Since the boiler does not know what time it is that sounds less likely!
Could it be that if you had run a bath during the day that the performance would have been the same as at night?
Tony
The plumber spent about 60 minutes. He cleaned a couple of parts and fiddled about for the rest of the time. The boiler fires up when the tap is run, but just no hot water. We are going to phone a another plumber and hopefully it won't cost too much.
Thanks for your time and responses.
Graham
With the system cold turn the hot tap on and feel the Flow pipe to the heating. If that is getting hot then its your diverter valve that's the problem and fairly common on these.
Worcester recommend a full replacement and if as I re-call they are a pain to get to, then so do I. If you do just get the diaphragm replaced make sure your repairer buys a genuine Worcester or 'giannoni' part. Giannoni is the make of DV that Worcester use in this model
The 240 is one of the easiest boilers to work on the diverter valve.
Usually there is no problem just replacing the diaphragm unit on this one.
However, the sliding joint onto the losenge shaped DHW HE always leaks afterwards. Its a good idea to have a new one ready as it can be a pain to stop the old one leaking.
Tony
Totally agree, but I now carry spare 'o' rings rather than this telescopic coupling.
About the only WB I will change the diaphragm on.
