I have bought a flat with what looks like a very old Ideal Classic LXFF Boiler and a Grundfos UPS 15-50 pump. I recently drained the system to replace some leaking pipework but I'm now having problems getting the system to fire up again. I thought I would go through what is happening in case one of you kind people can help me. (bearing in mind that I no little-to-nothing about CH or the correct terms!)
I have refilled the system and have checked all the radiators. They all seem to be free of air. If I try to fire up the boiler it will run for a few seconds before switching off. The casing of the boiler is warm. The boiler is set to 6 and the overheat switch is normal.
I can not hear anything particular coming from the pump but can honestly not remember how much noise the pump has ever made. It seems to be pretty silent and I can sense no vibration to indicate it is doing anything. I have tried bleeding the pump and get a contstant but slight trickle. I have turned the pump using a screwdriver and it seems to be free. The pump is warm/hot to the touch.
I have hot water tank that appears to be empty and is cold to the touch. None of the radiators are warm and I have no hot water form the taps.
Any suggestions on what could be wrong. My thought are that pump is dead but it seems starnge that this would go when I'm just replacing existing pipework. Any suggestions would be very helpful.
I am due to be replacing the boiler in the next few months but I don't think I can stand the cold showers much longer.
Cheers,
Steve
Cheers,
Steve
