- Joined
- 26 Aug 2016
- Messages
- 6,833
- Reaction score
- 1,010
- Country
Indeed, I think before condensing boiler came along they assumed the heat of evaporation/condensation wasn't of interest for heating purposes. Clearly as you state that's a bit silly, but back then they got away with it. But it's not quite wrong, according to the misleadingmisleading they used.However, correct me if I am wrong, but in the case of a gas boiler, is it not more of a case that the condensing unit is just recovering some of the heat that is being wasted in the combustion process?
This is a useful description http://www.lovekin.net/m.boiler-efficiency-gross-and-net.html
I'm sure if they can they will!I can't believe that any gas boiler is more than 100% efficient, or it would be marketed this way. I am thinking of efficiency in terms of 24kW of heat is created by a boiler, how much of that is useful heat, i.e. not lost to the outside through the flue. Surely that is the only worthwhile measure of efficiency?
Do you remember stereo systems in the 90s always advertised their rated wattage in PMPO. That was just some made up figure about 8 times the actual RMS wattage and much higher than the power consumption, meaning the stereo was supposedly well over 100% efficient.
Also some things are legitimately over 100% efficient. Take a heat pump for example. They are commonly 300% efficient as they use say 1kw of electricity and output 3kw into the room. Of course 2kw is taken from outside, but still the 300% is the useful figure to know in the marketing.
