We have a British Gas 330 condensing boiler, which is a customized version of a Glowworm hxi as far a I can see. I think it's about 10 years old.
We've recently had the radiators replaced by convecting models, which obviously required the system to be drained. Since then the boiler takes ages to bring the rads up to temp as it initially turns on and off, taking the boiler temp quickly up to something around 50degs, then dropping immediately back down to below 20, waiting for a few minutes then doing it again. This can go on for in excess of half an hour, very gradually building the temp up until it starts working continuously and staying on until a decent level is reached. The system has been bled several times, and there are no obvious cold spots on the rads.
Occasionally it gives up in the fluctuating stage with an error code of F26, which the manual tells me is 'max delta temp'. Stopping and starting the boiler begins the whole process again and the error code goes away for a few days.
Any advice would be very welcome.
