Presumably intelligent responsible design and manufacture.Where does this crap about 'if it requires a fuse it's provided internally' come from?
Are there fuses incorporated in your boiler, television set and other products that might require them?
But not when the 'piece of equipment' is made up from a series of components and once assembled together those components along with their thin cable require protection.In any event, as most people usually say/agree, if it is felt that a fuse of a particular rating may offer some useful protection to a particular piece of equipment, then there should be such a fuse within the equipment.
Kind Regards, John
Logically speaking, each and every piece of equipment (or 'component') which it is felt needs ('might benefit from') the protection of a low-rated fuse should have such a fuse internally.But not when the 'piece of equipment' is made up from a series of components and once assembled together those components along with their thin cable require protection.
For a television there will be a designer and that design will incorporate any required protection such as a fuse, the manufacturer will assemble the required series of components including the fuse until it becomes a functioning television.Presumably intelligent responsible design and manufacture.
So your television set contains hundreds of fuses to protect the components?Logically speaking, each and every piece of equipment (or 'component') which it is felt needs ('might benefit from') the protection of a low-rated fuse should have such a fuse internally.
Kind Regards, John
I think the problem here is that I would not describe a central heating system as a "piece of equipment" (any more than I would call a system consisting of interconnected computers, monitors, printers, scanners, network switches etc. as being "a piece of equipment").So who is the intelligent responsible designer and manufacturer in the case of a piece of equipment called a central heating system?
Yes, soon after I posted that I realised how you were probably going to respond - it was my mistake by 'following you' and using the word 'component' to refer to various items, scattered around a building, which one would find in a central heating system, not electric/electronic components within such items.So your television set contains hundreds of fuses to protect the components? Yes that is a rediculous question but I hope you can see the intent within.
With respect I don't think it's possible to compare an AV system comprising multiple interconnectable modular products with a heating system designed as wirable (actually stripping and terminating multicore cables) components. Equally I don't see how one can compare a motorised valve with a video recorder. When I mention TV components I'm referring to the mains transformer, bridge rectifier, smooting capacitor, IC's, resistors, inductors etc and I'm quite sure nobody would consider those parts require individual protection.I think the problem here is that I would not describe a central heating system as a "piece of equipment" (any more than I would call a system consisting of interconnected computers, monitors, printers, scanners, network switches etc. as being "a piece of equipment").
IF, hypothetically (analogous to a CH system) my television set consisted of several 'bits'(I'm trying to avoid the c-word!!), bought separately and probably of different manufacturer, and connected together by myself, in scattered locations in my house, and IF, for some reason, one or more of those bits specifically required ('might possibly benefit from') low-rated fuse protection then, yes, I would expect those 'bits' to have appropriate internal fuses.
Kind Regards, John
No. It is to protect the cable as always. All those accessories should be internally protected.I believe the requirement is to cover all circuitry connected to that of a gas appliance, so in the case of CH systems, pumps, valves, stats etc all need to be @ 3A max. So it can't be necessarily be satisfied by fitting a fuse in the boiler.
So you are suggesting all the CH installers in Europe are not in their right mind?Surely nobody in their right mind would consider connecting such a system with its 0.5mm² wires directly into a 32A, or even 16A, circuit without a smaller OCPD.
As we regularly see quoted on here 'The fuse is only to protect the cable'.
Will you please stop your irrelevant bleating-on about other countries electric rules/regulations/systems.So you are suggesting all the CH installers in Europe are not in their right mind?
...and, as we found out relatively recently in the P&CH forum, the 'Main Eco Elite' combi has two internal fuses; one on the live, the other on neutral.Just as an FYI, majority of boilers I’ve worked on recently have internal fast blow fuses, not sure if that’s relevant to people questioning boilers internal fuse protection.
It is not irreverent to compare with other countries for better or worse when manufacturers sell internationally.Will you please stop your irrelevant bleating-on about other countries electric
That doesn't make sense. What do you mean?It is not irreverent to compare
You are totally correctIt is not irreverent to compare with other countries for better or worse when manufacturers sell internationally.
