My guess would be something along the lines of : Boiler (gas appliance) is connected to various external devices, some of those devices can feed power into the boiler, we want a limit of a 3A fuse on such supplies. ... Possibly the simplest example is an S-Plan setup with a boiler having both permanent and switched live inputs. The permanent live probably powers the boiler's internals (and typically has it's own internal fuse), the switched-live input probably just triggers the "fire up" circuits (and should be internally protected against faults as well). As a secondary thing, you don't really want the external controls applying power to the switched-live input when the permanent live isn't there - that's a recipe for ..... Hence the BS7671 requirement for having a single means of isolation that turns off the entire system.
