Bolting a steel beam to another steel beam.
I'm talking about applying a modest pressure to the nuts without spraining the beam and then fully tighten them afterwards. What do you think might happen, lol?
When you did tighten them up did you do it to a particular torque? My fabricator reckons that's all a lot of s***e.
When you did tighten them up did you do it to a particular torque? My fabricator reckons that's all a lot of ****e.
Not especially. The bolts were quite snug and 'pinned' the beam securely without the nuts - i.e. there was very little movement once all four bolts were through. Make sure you have wiggle room as you offer the two beams together, as you need that bit of play to feed the bolts through. Get all four bolts through and nuts started and then crank them up.
All that's normally required with bolted joints is sensibly tight: no 6foot scaffold poles!
However there are occassions where bolts do have to be tightened very precisely. This is where HSFG bolts are specified: these are very strong bolts (which usually have a reduced diameter shank) and they work by pulling the mating surfaces together so tightly that high frictional forces develop.
They are common in steel frame structures but I have come across them once in a domestic environment. This one didn't end too well as the builder didn't understand what he was supposed to do and the steel sagged when unpropped and a lot of reworking was needed.
So your fabricator is right in your case but not neccessarily in general.
