Picture the situation. A chiller coldroom installed onto the wooden floor, with no insulated base (there may be insulation underneath the floor). A fan cooling unit hung from the ceiling inside (Searle twin fan) with power and pipework entering from above. Copper drainage pipe, well insulated (more on this later)
Next door is a freezer coldroom, smaller, but with the same Searle twin fan cooler, same installation method for cable and pipework. Metal plated insulated floor panels, floor raised up 4 inches.
The drainage pipe is also copper, however being in the freezer it has heat tape wrapped round it. The pipe from the freezer runs into the fridge along the back walls, through the single dividing wall. It joins to the fridge drain pipe, then goes off through the back wall, and through a steel framed stud wall. On the other side (still indoors) the copper pipe empties into a plastic one.
Now, is there any need to bond the copper pipe to the main body of the cooler unit in either case?
If so, why? Where is any potential going to come from in this scenario?
