Bosch Exxcel dishwasher Srs45e32gb water check light
13 Apr 2019
I have an ancient Bosch Exxcel dishwasher Srs45e32gb that has been working fine. I have put Finish dishwasher cleaner through it (something previous owners probably never did). The check water light is now coming on midway through a cycle. By jiggling the machine about it gets it going again until a while later when it happens again. Jiggling it about gets it going again. All the time it is doing this there is a whirring sound (the pump). The water supply pipe is fine. Filter on end of this is clear. Took left panel off machine. There is no water flooded into the base at all so no leaks. The plastic tubing is quite mucky (where the little red flood float is) and I've taken it off but cannot get inside it to clean it. However the red float seems to work fine and moves freely. Any ideas much appreciated. Thanks, Paul.
