Bosch PSR18VLI drill masonry/concrete upto 10mm?
20 May 2007
Hi
With the Bosch PSR18VLI 18V Li-ion Cordless Drill Driver, can I drill masonry and concrete, with 10mm drill bits? I'm looking to install kitchen cabinets, build them and fix them on walls.
Thanks in advance!
shouldn't be much of a problem for occasional holes. certainly wouldn't want to be drilling 10mm into concrete all day with it
idealy you need hammer /percussion for concrete thats why hammer drills are quite a bit more
you may be several mins per hole in brick/ block
but not realy any good for hard concrete :cry:
Most likely I'd need to do 8mm holes in masonry/concrete... The smaller the drill bit the easier to drill inside?
I've got a corded SDS, goes through stuff like butter, but it's bulky and heavy.
Thanks!
