Hi all
I have a camray 5 that keeps discharging water through the discharge pipe outside.it does this randomly with or without the central heating running.
I have two pressure gauges on the system and they both read 1.5 bar.
i'm sure the gauges used to work together but now they seem independent.
IE the one on the front of the boiler will read 0 but the one on the wall still shows 1.5 bar. I have checked both gauges and they seem to work fine.
When I charge the boiler only the gauge on the boiler moves.
I have replaced the pressure relief valve that's connected to the discharge pipe and the pressure regulator that's just before it but this has made no difference. My system is connected to a large hot water storage tank.
I have also checked the pressure in the expansion vessel on the front of the boiler.
The pressure on the gauges never goes above 1.5 even with water dripping out of the discharge pipe.
Any help with this would be greatly appreciated.
Nigel
Nigel
