I have one of the above boiler/burner combinations to heat my bungalow and it was probably installed in 1999. It has been playing up for a couple of years by not starting up when it should.
When it refuses to start automatically, it can be started by manually pressing the "Reset" but occasionally needs a thump to get it moving. Various boiler "engineers" have charged me various sums to change the motor, realign the motor, clean the pump, flush out the oil supply lines, etc. but it always seems to end up, after a short while, with the same problem.
The fact that it sometimes needs a mechanical disturbance to set it going makes me think that there is a bit of mechanical interference somewhere - as the motor etc. slows down, when it switches off, it turns until it hits a "tight spot". Then, when it is called upon to start, it cannot initially overcome the resistance of the "tightspot".
Has anybody got any thoughts about where I should be looking to solve this problem. Riello don't list the burner and the Boulter boiler is long since out of production.
Are there any sources of information available, other than this forum, where I could get some expert advice?
CVB
CVB
