Just moved in to a house with a oil fired Boultler Boilers Comray Compact hot water and central heating boiler. It has a hot water storage tank with a header tank. Not sure if this indicates that is a sealed system or not.
The issue is the 'Limit' light keeps coming on and has to be reset.
What temperature should the limit thermostat kick in?
There is a temperature dial on the front of the boiler from 50oC to 90oC, am I right in thinking that with a fully functioning boiler it would be O.K. to set it at 80oC-85oC?
Does anyone have a manual for this boiler?
Kind regards
Jon B
Kind regards
Jon B
