Main Eco Compact Combi Boiler
2 Feb 2016
A family member just moved into a property that has a new Main brand Eco Compact Combi Boiler which I think is by Baxi, link below seems like this is the one:
https://www.mainheating.co.uk/main-products/gas-boilers/combi-boilers/main-eco-compact-combi
There seems to be no room thermostats anywhere in the house at all to control the boiler and as a result the boiler seems to just stay on all the time. There is only two dials that you use to control the heating temperature and the horn water temperature. There is no place to actually turn the heating on or off. I don't see any timer either, otherwise that could have been an option.
Can anyone advise is there a easy way to turn the heating on and off at the boiler without turning the power to the boiler off and losing hot water?
Also, how hard will it be to wire some sort of wireless thermostat to this boiler?
Thank you.
you will have to wire in some kind of external control as long as it is voltage free switching, can be wireless if you want, nothing difficult in doing it , if you can follow basic instructions
Will you be able to guide me which page on the user manual refers to installation of the thermostat? From what I understand a thermostat essentially sends a relay activated switched live to the boiler telling it to turn in right? Could you guide me to the wiring diagram on the boiler end if possible please?
So looking at the following installation guide: https://mediacdn.mainheating.co.uk/...main-eco-compact-combi-installation-guide.pdf
Page 42, figure 35 seems to show the connections. I've found a wireless thermostat with opentherm connectors. So I'm assuming I just need to take the live and neutral connections from the boiler to the receiver. And take two opentherm wires to pins 1&2 from the receiver. Any thoughts?
be careful, the Baxi doesnt accept "all" opentherm controllers.
it doesnt work with Hive, i cant remember the issue, but it would turn it on once then continue not to work until it was rest or something, i cant remember exactly now it was a year ago, my boiler install was delayed a few days as the installer was stuck trying to fix it between baxi and nest in the end he had to set it the old fashioned way as it turned out the baxi expects another packet of information which the nest doesn't send or something.
it should work witht he honeywell t6r though as that sends out virtually all possible opentherm commands/packets, but maybe someone who installs these all the time can confirm.
Decent boiler (for the price), crap design
Who designs a boiler where one is unable to turn off the rads?
I stuck a google nest on mine.
Installing a thermostat is easy work. Don't be intimidated and just follow the instructions in the manual
yes if using OT if not use diagram G and connect the two blacks to the switching wires on the receiver (will be 240V switching) if you use OT then the yellow wire in diagram G has to be removed, as said Nest supports OT but whether it works withBaxi I cant say but someone else saying it does
I have one of these, as someone said above poor design as you need to have ability to switch heating off on boiler, but no the manufactiruer leaves all that to controls wired in, another thing that would have helped is when in operation it would be nice to have a LED backlight come on the visual screen.
Mine is controlled by a salus i500 which actually works despite being a bit laggy.
OT controls lets you control thermostats temp AND water/boiler temp as well (making the dials on the boiler redundant).
I've ordered a EPH Combi Pack 4 Wireless Thermostat which I've been told is compatible with this boiler and it's opentherm too.
Question regarding opentherm, is there a +/- wire or can the wires from the thermostat receiver's opentherm pins go in any direction to pins 1&2 of the boiler terminals?
Looking at the receiver specs of the EPH Combi Pack 4 wireless thermostat, the receiver spec says it's 10(3)A rated. Is that 3A or 10A? what kind of cable should I use to wire it 1mm2 or 1.5mm2?
For the OT connection can I use any cable or does it have to be a certain type of cable? What kind of voltage etc will the OT pins carry?
0.5mm it's very low voltage and current. Don't run alongside power or lighting. Usually very short between receiver (if RF stat) and boiler. The electr guy here would probably say network cable, I don't know. I used to run the AQ6000 in bell wire.
