guys, thanks for all the previous help, I have now 'looked' at the problem for 24 hours, time soon to get some pipes cut !!!
OK - please hear me out, as I think Im losing my mind, BUT;
a) I have only 15mm pipes in the bathroom
b) I wish to use a 15-22-15 push-fit TEE, so that i can use all 22mm tubing to the 3/4 bath taps
MY THEORY is that by using a large dia. pipe, I am maxismising the flow rate to the bath taps
( Or at least, not reducing it any further, if i used 15mm pipe with 15mm elbows etc )
IS my theory correct ?
or will using 22mm pipes on a 15mm source, be a problem ? i was thinking that it might affect the ' load ' IE 15mm flowrate , having to 'push' 22mm water load ?
BASICALLY, I didnt think fitting 15mm pipe, with all the elbows etc would be a good idea, as it would reduce the flow rate even further..........combi boiler is powering the system, even still, 15mm pipes for bath taps ?
* ALSO, can I connect up plastic pipes all the way right onto the bath TAPS ( 3/4 to push-fit connector ) OR SHOULD I use flexi-pipes to make pipe to tap ?
Christ, I wish they taught this at school, its bloody far more difficult than first meet the eyes !!!
cheers
Boogsy
cheers
