Does anyone know a supplier for brown coloured electrical cable? I'm wanting to wire in some outdoor lights and would prefer for the cable to blend into the bricks as much as possible.
Thanks.
Thanks.
How many cores? What size conductors?
1 or 1.5mm. You’ll not get 2.5mm in the terminals of most lights and switches!
Google is probably your best friend on the supplier search.
Twin and earth [or 3C&E] isn't really the right stuff to use outdoors.
Indeed. I've done that a few times, albeit a bit tedious for longish lengths of cable!Brown heatshrink over cable of another colour.
Kind Regards, John
Really surprised there is only standard grey wire to buy.
There are several standard colours, but not all of them.. As mentioned above, the flat grey cable is not for outside use in any case.
Look for round flexible cable , preferably rubber, then your choice will probably be black or white.
I've done it for pretty long lengths in my time - but, s I said, it's a bit tedious. Another option is to paint it1Yeah didn't till I'd have to stoop to such activities to be honest, can't do that for 20 metres.
It's really just a matter of (the lack of) demand, particularly for T+E cable (which, as said, is theoretically not suitable for outdoor use). The vast majority of T+E is not visible when installed (within walls, under floorboards, above ceilings or in trunking etc.) and, on the relatively rare occasions when it is visible, that's an indication that the user doesn't care what it looks like, and therefore won't be concerned about the colour.Really surprised there is only standard grey wire to buy.
However, as has also been said, flexible round cables come in all sorts of colours, including brown - but you would again need to make sure that what you chose would be suitable for outdoor use.
Kind Regards, John
