BSPP vs BSPT confusion - please help
2 Feb 2025
I have a Hansgrohe Universal iBox and a Hansgrohe Concealed basin mixer valve to install.
The product data sheet says that the threads are Rp which I understand is for the parallel not tapered.
Please excuse me if the question may sound dumb and my lack of knowledge, but trying to learn from experts :)
So from what I read, since the valves are marked as RP on the valve body I need a BSPP (Parallel thread) fitting to thread into it because RP is parallel. But what is confusing me is that from what I can see a parallel thread connection usually means its those connections where the tip is flat for a rubber washer to compress and provide a tight seal so that water doesn't get past the rubber seal into the threads. So BSPP is sealed with a flat washer and not sealed at the threads using ptfe etc (my understanding so far :) ). So this is where I am confused because the Hansgrohe official user guide and youtube video installation guide shows them fitting a threaded connector to the valve body but there is absolutely no rubber washer but instead they show themselves putting something like Loctite 55 cord the equivelant to PTFE i guess on the thread and then tightening it. So this is where I am left really confused. So both the iBox shower valve and the Basin mixer valves have the RP female threads as part of the body. Do I get the BSPP (arallel thread) male thread connector to go with this or do I get the BSPT (Tapered Thread) male connector to go into the RP female connection? If BSPP, then does that not mean I need to put some sort of rubber washer to create the seal?
This is a tad bit confusing so would really appreciate some guidance and advice on this as I want to do it right the first time.
Thank you
Not something that has ever come up with me, I use standard parallel thread adapters with PTFE.
So it’s perfectly normal to use a parallel thread male thread bspp connector without using a rubber washer? Just using ptfe? So i should avoid tapered bsp connectors on a Rp female body?
I just read somewhere that on an Rp which is the female parallel thread on the valve body that you can use a R male BSPT as long as it’s got the likes of ptfe or loctite etc. is that true? I’m struggling to actually find any male thread BSPP that has soldering joint on one side.
Either or, it doesn't matter on a shower.
