- Joined
- 31 Aug 2005
- Messages
- 4,738
- Reaction score
- 967
- Country
Ive done a bit of research and designed the building and how i want it to look, but would appreciate some advice on my construction methods!
First of all as you can see below the base is 6.5 x 3.5 do i use concrete or timber, if i use timber how far apart should i space the supports, how deep in the ground, do i use concrete slabs in the base of the hole, cement round, or lay them on the surface on top of concrete.
A base this big is going to be heavy to lift its not like i can build it and lift across onto the supports, not unless i go the concrete route, which im guessing i lay it directly on top of some damp proof layer? If i use concrete how thick or deep should i go.
Many questions!!
Many thanks in advance.
[/img]
Many questions!!
[/img]
